McCormick XTX 200- Nie działa EHR
Witam pierwszy błąd o czujnika położenia ramion
Hitch Error Code 2174
Fault Description.
Hitch position (lift arm) potentiometer circuit failed, position potentiometer signal voltage outside the 0.3 to 5.0 volt
limit.
Response.
Fault Category - LIMP. Hitch enable light will illuminate and the hitch will only operate for 1.5 seconds using the
hitch up/down switch or hitch remote switches repeatedly.
Possible Cause.
1. Bad hitch position potentiometer.
2. Bad hitch position potentiometer circuit short to voltage above 5 volts.
3. Bad hitch position potentiometer circuit short to ground.
IMPORTANT: Before carrying out the following tests, refer to “CIRCUIT TESTING” on page 16.
Circuit Checks/Corrective Action.
1. Check the hitch position potentiometer is located correctly into the mounting bracket and the retaining
nut is tight. Also check the potentiometer link arm located correctly retaining allen screw is tight.
2. Check the hitch position potentiometer.
3. Check the hitch position potentiometer circuit.
witam potencjometr wymieniony wyskoczył błąd 2203 podnośnik nadal nie działa dodam że w górę przyciskami w błotnikach reaguje poszedł na 100 % a w dół zero reakcji
witam
Hitch Error Code 2203
Fault Description.
The Hitch position is above the upper limit.
Response.
Fault Category - DEGRADED 1. Hitch enable light will illuminate and the hitch will operate under default settings
only.
Possible Cause.
1. Hitch position command (cab) potentiometer moved during power down.
2. Bad hitch position command (cab) potentiometer.
3. Bad hitch position command (cab) potentiometer circuit.
1. Press and hold the hitch up/down switch in the momentary position or the hitch remote down switch
down switch until the hitch upper limit is reached.
2. Check the hitch position command potentiometer.
3. Check the hitch position command potentiometer circuit.
W moim przypadku oprócz ww. kodu błędu Ehr 2174 pojawił się drugi błąd Ehr 1501 oraz błąd Scr 03dE06. Co oznaczają te dwa błędy?
Z góry dziękuję za odpowiedź i pozdrawiam.
U mnie błąd 2203 wymieniony potencjometr w środku od radaru błąd znikł . Pojawił się błąd 2174 serwis twierdzi że to potencjometr z tyłu na ramionach.a podnośnik nie działa nadal .
    • Przez Zomii
      Witam czy ktoś wie jak ustawić rozrząd? Mc Cormick D-439
    • Przez zadenrolnik
      Cześć wszystkim,
      Stałem sie niedawno posiadaczem MC95 i jest to mój pierwszy ciągnik.
      Chciałbym w nim zrobic serwis olejowy i nie mam bladego pojęcia ile i jakiego oleju najlepiej kupić. Skrzynia, przedni most i silnik.
      Prosze o polecajke
      Jeżeli macie jakies sugestię, na co jeszcze zwrócić uwagę i co ewentualnie jeszcze wymienic to piszcie smialo.
    • Przez AdamAdam1993
      Cześć zastanawiam się nad kupnem Mc Cornik 5.085 co jest bliźniaczym modelem dla Landini 5.085. Bardzo proszę o opinię użytkowników tych ciągników wraz z informacją ile mtg już zrobili i co się popsuło w tym czasie.
    • Przez Dx90luberda
      Witam problem z moim mc115 silnik kreci nie odpala pompka dobra przewody do baku sprawdzone .
    • Przez caros2
      Czy ktoś wymieniał przeguby osiowe? Czy są problemy z tą wymianą?
