Nowość od Zetora - czyli "HithTronic"
Zetor zaprezentował dziś swój nowy system HithTronic, czyli automatyczne sterowanie tylnym tuzem dostosowującym się do kształtu terenu. Zetor chwali się również że stworzyli pierwszy "inteligentny" traktor. W system mają byś wyposażone wszystkie modele Forterry od 2012 roku.
Cały tekst dotyczący wspomnianego systemu:
Unique innovation by Zetor
The tractor gets adjusted to terrain conditions automatically!
Zetor has introduced a unique technological innovation making the job of all farmers easier. HitchTronic is a new function which automatically regulates the rear three-point hitch so that the tractor gets adjusted to the terrain without the necessity of the operator to control it. This makes the operator’s work much easier. It shall be appreciated not only by novices to the job but by experienced tractor drivers as well.
Brno, 9. 12. 2011
HitchTronic software makes operating Zetor tractors more comfortable and much simpler. The only thing that must be set by the operator is the required depth of tillage and HitchTronic automatic regulation adjusts other settings of the tractor during the whole course of work.
“Automatic regulation guarantees an easy and intuitive control of the tractor without complicated instructions. Moreover, it is effective as this way good working results can be achieved independently from the skills of the operator, the quality of soil thed the type of device.If compared to manual non-optimum adjusting, it has been proved that activating HitchTronic results both in fuel saving and increase in work efficiency,” Marián Lipovský, deputy CEO and production director of ZETOR TRACTORS a.s. said.
Of course, activating HitchTronic automatic regulation does not affect the functionality of other existing features of electronic regulation of the tractor’s lifting mechanism in any way. At any time, operators can switch between automatic and manual regulations and control the adjusting of all working parameters themselves.
HitchTronic Software is going to be newly installed in all produced models of the Forterra range from January 2012 on.
Activating HitchTronic is really easy. To set Hitchtronic , turn the potentiometer (power/position regulation) to the “red” area. After reaching set position, the power which is used as rated value is measured and regulation is activated. Repeat this any time you change settings of the switch or potentiometer.
Co myślicie o nowym systemie?
Gość Profil usunięty
Nowinka bardzo ciekawa tylko jak się będzie sprawowała.....
Zapowiada się również poszerzenie serii Forterra o nowe modele.W połowie tego roku mają się pojawić maszyny z oznaczeniem HSX. W tej nazwie HS to sktót od słów Hydraulic Shuttle, czyli rewers elektrohydrauliczny, natomiast X oznacza PowerShift, czyli wzmacniacz momentu. Dostępne będzie pięć maszyn o mocach 90, 101, 110, 122 i 137 KM. W układzie przeniesienia napędu umieszczona zostanie synchronizowana skrzynia wyposażona w pięć przełożeń głównych co w połączeniu z załączanymi elektrohydraulicznie 3 półbiegami i dwustopniowym wzmaczniaczem momentu da w sumie po 30 biegów w obu kierunkach.W ciągnikach Forterra HSX wzmocniony zostanie podnośnik co pozwoli na podnoszenie ciężaru sięgającego 7 ton. WOM będzie można sterować na zewnątrz, dzięki umieszczonym w tylnich błotnichach przyciskach. Ponadto na wyposażeniu standardowym znajdą się aż 4 prędkości WOM (540/540E/1000/1000E).HSX otrzymają również amortyzowaną kabinę z przeszkloną przednią częścią dachu. Kostruktorzy Zetora zapowiadają również kolejną Forterre HD. Ich wprowadzenie przewidziane jest na 2013 rok. Będą dostępne modele o mocach 120, 130 i 140 KM. Biegi będzie można zmieniać elektrohydraulicznie za pomocą joysticka. Będzie amortyzowana przednia oś, będzie nowa pompa o wydatku 80l/min. Przewidziana masa Forterry HD to 6,3-6,5 tony
kurde za parę lat to ciągnikiem to się będzie chyba z domu kierowało, albo do komputera wprowadzisz dane i sam będzie po polu jeździł a człowiek czym innym się będzie mógł zająć :)
Co do hichtronica to juz mialem okazje zaorac u siebie 5h i musze stwierdzic, ze to rzeczywiscie dziala ;) oralem na ciezeszej ziemi 2-3 i lzejszej 4-5 i caly czas na auto a plug idealnie trzymal glebokosc :)
Hsx napewno nie bedzie kosztowal 270000, jak wyzej cena pewnie bedzie wyzsza o okolo 20000 od standardowej forterry
Szczerze to nie wiedziałem gdzie to wstawić ale uznałem że to będzie odpowiedni temat.
Na Czeskiej stronie Zetora [www.zetor.cz] od jakiegoś czasu w zakładce "Produkty" widnieje model Zetor Forterra HSX.
Czy ktoś już go z was widział? Nie wiem, więc dla tego pozwoliłem sobie zamieścić tutaj wszystkie informacje przetłumaczone na Polski.
Zetor Forterra HSX
Najsilniejsze i najlepiej wyposażone traktory w gamie Zetora.
Wytrzymałość - Odporność - Wydajność
Forterra hsx jest wyposażona w najnowsze technologie: ostatnia generacja power shuttle, nowa pięciostopniowa skrzynia biegów z trzystopniowym wzmacniaczem momentu [?], także wydajniejsza hydraulika, hitchtronic, wyświetlacz lcd, dłuższy rozstaw osi zapewnia większą stabilność ciągnika, bezpieczny fotel kierowcy i dalej - to jest siła, wytrzymałość i sprawność od Zetora.
Skrzynia biegów
Pięciostopniowa skrzynia biegów z trzystopniowym wzmacniaczem momentu [?] i rewersem pod obciążaniem [?] oferuje 30 biegów w przód i w tył. Nowa konstrukcja zapewnia użytkownikowi mniejsze [dalej nie wiem].
Kabina
Deska rozdzielcza z wyświetlaczem LCD z munstwem infromacji dla kierowcy i elektronika z CAN dla łatwego serwisowania. Wyłącznik bezpieczeństwa w fotelu kierowcy w celu poprawy bezpieczeństwa kierowcy.
Silnik
Traktor Forterra HSX są wyposażone w 16. zaworowe silniki cenione za wysoki moment obrotowy (ponad 36%), dzieki któremu 225 litrowy zbiornik wystarczy na cały dzień pracy.
Hydraulika i PTO [WOM?]
Dwa dodatkowe siłowniki hydrauliczne zapewniają równomierne obciażenie ciągnika i udźwigu do 70kN. Modele Forterra HSX są wyposażone w najnowsze technologie automatycznej regualcji trzypunktowego podniśnka HitchTronic [?].
To taki prototyp tekstu, jutro będzie poprawiony i dodane będą "Dane techniczne".
Za wszelkie błędy przepraszam ale aż tak Czeskiego nie znam...
PS. Tam gdzie widnieją pytajniki "[?]" to takie pytanie do was, czy coś takiego w ogóle istnieje co napisałem :lol: .
Pozdrawiam.
Tak, bo Frotka HSX jest wyposażona w elektrohydrauliczny rewers, przekładnię z 3 półbiegami i EHR z Hitch-Tronic, Zdjęcia są oczywiście na AF, z wyglądu jest trochę dłuższa ze względu na nową przekładnię.
    • Przez fendt614
      Witam ,szukam pomocy z racji tego że założyłem rozdzielacz nieco do tura stoll robusty F35 podłączyłem go bezpośrednio z pompy  T1 jako szeregowo do podnośnika jako drugiego rozdzielacza a T2 wolny spływ w skrzynia,.Pierwsze podpięci i kombinacje podpięcia tura pod 4 gniazda powinno być złącze Faster, moje pytanie jest takie czy przez źle wpięcie od tura moglem rozerwać pompę A1,A2,B1, B2 , czy po prostu ktoś podkręcił zawór ciśnieniowy na maksa że pompa nie wytrzymała? Jak logiczne i tanio sprawdzić rozdzielacz bez uszkodzenia kolejnej pompy, założyć kolejny zawór ciśnieniowy zabezpieczający odrazu za pompą?
    • Przez grzechu17
      Witam,sprawa wygląda następująco sprężarka chodzi ale nie bije powietrza. Co może być przyczyną?
    • Przez lukaszeekk24
      Witam do czego służą te pokrętła
    • Przez rolnikus21
      Witam, wczoraj zaczęły mi wariować wskaźniki na desce rozdzielczej. Temperatura spadała i podnosiła się, paliwo oraz powietrze spadało do zera.
      A teraz mam jeszcze problem że piszczy pod wskaźnikami na desce rozdzielczej.
      Sprawdzałem alternator, naciągałem pasek, sprawdzałem przewody pod deską i wszystkie wydają się w porządku.
      Czy ktoś wie jak to naprawić?
    • Przez Radek221
      Hej. Zetor proxima 7441 zgasł w trakcie jazdy, podczas rozebrania silnika były połamane 2 laski popychaczy reszta wygięta, po wymianie popychaczy i kreceniu kluczem wału zawór blokuje o tłok, rozrząd ustawiony prawidłowo. Wałek rozrzadu jak nowy głowica dwa lata po naprawie co może być przyczyną ?
